ExtLibA.Socket.GetPktInfoFail
Description
Failed to get packet information. Note: If the traced error number, %2, is 0 then the IP stack did not provide the required ancillary data.
Remedy
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Severity
Warning
Message Text
Failed to get packet information using IP_PKTINFO or IPV6_RECVPKTINFO. Socket = %p1% recvmsg error code (or 0 if none) = %p2%
Message Parameters
Name Type
p1 xInt32
p2 uInt32
